Removing/ replacing heads
Old Sep 30, 2006 | 09:53 AM
  #51
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
How did you adjust the rocker arms....or did you at all????
Old Sep 30, 2006 | 11:41 AM
  #52
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
a rod knock means your bearings are shot. You would generally have to replace the crank, and some/all of the rods. turning the crank usually won't save it.
The knock is the pistons hitting the head. Lets hope thats not it.
A stethoscope can help you pinpoint the sound.
A good mechanic will have heard all the typical sounds, and can tell you what it is, better than we can over the internet.
Old Sep 30, 2006 | 12:16 PM
  #53
Brandon Crawfor's Avatar
Car: 1982 Camaro Z28
Engine: 350 V8
ive got a manual (engine rebuilding and whatnot) and its got a diagram or whatever that shows tells how the rocker arms should be adjusted
i just followed that...
...i hope thats not it... son of a b*tch...
ill prolly just park it til i can figure out exactly whats wrong with it
Old Sep 30, 2006 | 03:12 PM
  #54
Engine: 350 V8
could adjusting them improperly have something to do with a knock?
and the knocking isnt consistant, sometimes its lighter, lower, or fast or slow, and its not really depending on my operation of the throttle, it just kinda fluctuates...
its weird
Old Sep 30, 2006 | 03:56 PM
  #55
84L69TA's Avatar
Car: 4 Mopars total
Rocker arms wont knock, theyll clatter if they are too loose. To an untrained ear, it could be mistaken for a mild knock. But if the noise is irregular or inconsistent...that probably rules the rocker arm theory out. Anyway, its best to adjust them with the engine running.
Old Sep 30, 2006 | 04:01 PM
  #56
Sonix's Avatar
Car: 1982 Trans-Am
yea, loose or misadjusted rocker arms usually rattle, or "tick". But yea, they're free to adjust so might as well check 'em. you'll get soaked in oil if you do it with the engine running (or use oil deflectors). But you can pull off a valve cover (or both) with the engine running. If the sound is louder, and you can see one rocker looking "funny". Shut'er down and check it. If it's loose and floppy, fix it.
I wouldn't be able to sleep at night parking my car with an unknown problem. You sure are having bad luck with the motor, but i'd at least find out what it is before heaving it on the back burner for the winter.
Old Sep 30, 2006 | 04:26 PM
  #57
Engine: 350 V8
well im thinkin if i can find another 305/350, ill "just" swap them out and then illl take care of this engine when i go to college next year, because i plan on taking a course in engine performance, so ill be putting to use what i learn there
also ive kinda been thinkin and i came up with a stupid-ish idea,
but just for the hell of it
could it be possible to replace the rod bearings WITHOUT completely removing the engine? maybe jack it up, remove the oil pan, stuff like that?
it would prolly be hard... but its just a thought
Old Sep 30, 2006 | 06:25 PM
  #58
Sonix's Avatar
Car: 1982 Trans-Am
good thought, but it's physically impossible. Also, the rod bearings won't save you from a rod knock, the crank will have worn too far.
Hey, got a digital video camera? get some sound of it. Or like I said, show it to a mechanic, get an opinion to be sure.
Old Sep 30, 2006 | 07:52 PM
  #59
Engine: 350 V8
son of a b*tch
well ive decided to just rebuild the motor,
using alll the same parts (save for the crank) unless something like the cam is worn or bent,
but i didnt really want to get into this right before winter is gonna start
but at least ill be done with it for awhile
til i get to college anyway
Old Oct 3, 2006 | 10:13 PM
  #60
Engine: 350 V8
Well i tried adjusting the rocker arms,
but
now when i try to start it it starts, and then it starts squealing/squeaking, and shudders
wont hold an idle and dies after about fifteen seconds of running
wtf?!
Old Oct 3, 2006 | 10:50 PM
  #61
Sonix's Avatar
Car: 1982 Trans-Am
what the hell?
squealing? Did you over tighten the accessory belts?
How'd you do the rocker arms? Musta screwed them up, try again I guess.
Old Oct 3, 2006 | 11:51 PM
  #62
Engine: 350 V8
well some of them were loose enough to where i could turn the pushrods with my fingers,
so i tightened them until i couldnt move the rods any more,
then turned each one its respective amount of degrees according to the diagram i had used before
i dunno whats going on but whatever
Old Oct 4, 2006 | 12:07 AM
  #63
Sonix's Avatar
Car: 1982 Trans-Am
whoa!
You just tightened them up where they were? You didn't rotate the engine over at all while doing this?
Old Oct 4, 2006 | 07:02 AM
  #64
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally Posted by Brandon Crawfor
nevermind, i got rid of the smoke
took her out, she stuttered alot and couldnt get up there (speed wise)
so i retarded the timing
now under acceleration she knocks,
so i advanced the timing just a little
but
i figure ill prolly take it somewhere so i can have the ignition timing set professionally, cuz i dont think i should mess with it too much
but you guys were alot help, thanks
If the engine isn't highly modified, it should run properly on the factory timing, if it doesn't you got other problems.
If it's vacuum advanced then you should do it yourself. if it's computer controlled you can still do it yourself, but you'll need to disable the computer's control of the timing, and set it to factory spec (say 8°) because the computer is already programmmed for 8°. This procedure is equivalent to disconnecting the vacuum hose on a vacuum advanced distributor.
Old Oct 4, 2006 | 03:28 PM
  #65
Engine: 350 V8
whoa!
haha,
no
i turned it over about 2-2 1/2 times doing each valve or whatnot
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
BBSDesigns
Aug 11, 2015 07:39 PM
