please help me my car is acting up.
Old Sep 9, 2006 | 11:48 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
please help guys. It all happen tonight I just droped my girlfriend of i was driving home and my car just switched gears from 2 to 3 and i was driving in low rpms and when i was in low rpms my car started shakeing very hard. So I let of the gas and came to a stop. when i was at a stop the car was ideling very rough and making a ticking or nocking noise. I think it sounds from under the car. now my car has a very rough idel when in drive and the engine sound very different. please help this is my daily driver
Old Sep 11, 2006 | 04:26 AM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
first check your vacum lines. my wife's car did the same thing. transmission was acting up and the engine was running eratically. turned out to be a vacum line on the intake manifold. sure sounds similar to your problem.
Old Sep 11, 2006 | 12:58 PM
Car: 91 formula
thank you for your respones. I will be checking them soon. does anyone else have anything to say about this or any other things I should look for. i need it to be up and running again ASAP. thanks
Old Sep 11, 2006 | 06:27 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
is it rough only when in idle? or is it constant?
if its a constant knocking tinking sound, u might have a knock.. worst thing ever could happen.
but like he said, vacuum lines, clogged fuel filter etcs can also cause very rough ride too.. so lets hope u dont have a knock..
if its only in idle, then along with vacuum I'd check idle air control valve etcetc..
Old Jul 10, 2007 | 02:46 PM
SirMarT42's Avatar
Car: 1991 Firebird
Engine: LHO 3.1 L V6
Transmission: A4
Re: please help me my car is acting up.
o2 sensor?
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
customblackbird
Aug 15, 2021 10:16 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
