A/C Compressor Clutch
Old Sep 11, 2006 | 12:22 AM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Recently after an extended trip my A/C compressor clutch started smoking. It was not able to turn the compressor and would only smoke when it was turned on. Later, after the engine cooled, the A/C worked fine. Is this a bad clutch or is the compressor starting to lock up? I had the system converted to R-134a in May. Also, how difficult is it to replace the clutch, and does it requre any special tools. Thanks.
Old Oct 1, 2006 | 10:14 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Anyone?
Old Oct 1, 2006 | 10:18 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
what i have experienced in the past with ac compressors is if your clutch is going bad replace the entire compressor,much cheaper in the long run.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
mfp189
Sep 27, 2015 09:25 AM
