Connecting Rod Orientation?
Old Oct 1, 2006 | 10:40 PM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Does anyone have the definitive answer on which way stock rods belong?
I think my machine shop might have pressed them on backwards. The stock rods have an offset to them at the crankpin end. I have all of the pistons and rods installed and when I look up at the bottom of the pistons, the rod is not centered. It looks like if I rotate them 180 degrees, they would be. But, that would make my pistons grooves facing theback of the engine?! I have built engines before and never ran into this. I just want to be on the safe side. My GM factory manuals do not mention anything about this.........
Randy
Old Oct 1, 2006 | 10:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The bearing tangs in the rod should be facing "down" or away from the cam.
Old Oct 1, 2006 | 10:48 PM
randy4762's Avatar
Do you mean on the rod's cap the tang on the side?
Old Oct 1, 2006 | 10:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the one.
Old Oct 1, 2006 | 11:06 PM
randy4762's Avatar
I just rechecked and took photos, everything looks good! I could send them to you for a second opinion. I'm glad I decided to quit while I was ahead. There is nothing wrong! I guess am just tired.
Thanks for the help.
Old Oct 1, 2006 | 11:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure, post them if you want.
Old Oct 1, 2006 | 11:22 PM
randy4762's Avatar
Here is some photos of the build
Attached Thumbnails Connecting Rod Orientation?-eng1.jpg   Connecting Rod Orientation?-eng2.jpg   Connecting Rod Orientation?-eng3.jpg
Old Oct 1, 2006 | 11:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those look ok to me, as long as the machined faces on the big ends of the rods are facing each other as they're supposed to.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
