Replacing In tank fuel pump with hose
Old Sep 11, 2006 | 01:43 AM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
In a day or two, I'm pulling the electric fuel pump from my tank, I'm going with a mechanical fuel pump.
I have read in some old threads that I can use fuel hose in it's place as a pickup tube, however, I am unsure of the diameter I would need.
If anyone has done this LMK what size you used.
Old Sep 11, 2006 | 02:43 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I believe that your fuel sending guage is part of your fuel pump assembly.. in fact I am almost positive since everytime i asked if someone had one they always gave me one as "Fuel sending unit w/ electric fuel pump" so you may run into problems with your fuel guage if you do that perhaps?? I didn't need a fuel pump just the guage since mine came with a mech fuel pump on the block..
Old Sep 11, 2006 | 12:53 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
When you pull your sending unit out you will see that your fuel pump is hooked to the sending unit with a small piece of rubber hose already. Take that piece and match up the size.
You can lay your old pump with the small piece of connecting hose still hooked to it on the bench next to your sending unit and then cut your new hose to the same length.
You should be good to go after that?!!
Good luck!
Old Sep 11, 2006 | 01:14 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
I did that, but I put a metal tube inside the rubber hose to keep it from closing up.
Old Sep 11, 2006 | 02:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/forums/carb...nk-pickup.html
I particularly like this because it maintains the inlet screen with a readily available part.
Old Sep 11, 2006 | 03:17 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
thanks for all the replies, looks like I won't have as hard a time with this swap as I thought.
Old Sep 13, 2006 | 05:50 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Update
Just a bit of information for those of you wanting to remove your in tank pump. The job of removing and re-installing the fuel tank took about 8 hours (including a trip to the Auto Parts store).
The line I used in place of the fuel pump was a 5/16" fuel hose. It looks like if you prefer to use metal line it would be easy to substitute it in place of the fuel hose.
Also, If you don't intend to use a fuel pump with a return port, you might be able to use the return line as a fuel pickup tube, since it goes all the way to the bottom of the tank.
So far I've been happy with the results.
Old Sep 14, 2006 | 06:47 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Another note that's helpful to those that are wanting to do this, if you're going to run the pick up hose to the bottom of the tank, cut a small V Shape at the bottom of the hose. The V Shape will prevent the hose from suctioning itself to the bottom of the tank which would prevent the intake of fuel. If you leave the hose flat on the end you risk the chance of this happening.
Old Sep 30, 2006 | 11:21 PM
Dragonsdeath's Avatar
Car: 87 Trans AM GTA
Engine: 80-84 305 carbed
Transmission: TH350
Axle/Gears: posi w/ disk breaks
This is what Im trying with the engine I just put in the GTA I got.
so far it seems to work, I just put a glass fuel filter in the line just befor the mechanical fuel pump on the block. Im thinking of putting a second glass fuel filter in line just to be safe.
Im wondering what risks are involved in useing the factory return line as a pick up line since it doesnt have a sock at the end?
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
