HEI
Old Sep 15, 2006 | 12:29 PM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
HEI
Whats the best way to unplug the coil on a distributor with the coil in the cap. It's loose and I can wiggle it back and forth, but it wont unplug and I really dont want to break the connector This is on an 84 305
Old Sep 15, 2006 | 12:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
there is two tangs on either side of the plug that you need to spread out with a screwdriver before the plug will pull down.
Old Sep 15, 2006 | 08:02 PM
Damon's Avatar
Yeah, and one similar lock connector on each of the other two terminals (+12V and TACH). The 3-wire jobbie towards the inside you have to pop off both the locks at the same time or it won't pull off.
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
