What kind of Heads ???
Old Sep 15, 2006 | 09:09 PM
bert4's Avatar
Car: 1987 Iroc
Engine: 305 T.P.I.
I have a 87" Iroc w/305 that will need a valve job this winter. Can I just get some heads off a newer Chevy Vortec motor that will work? If so what should I look for (motor size, ect.)
Old Sep 15, 2006 | 09:26 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
"vortec "heads have raised intake ports and a differenct intake bolt pattern. Requires a vortec specific intake manifold. If you want to adapt vortec heads to your TPI motor you need to buy a vortec TPI manifold and make a few EGR mods etc. The vortec heads to look for have a "062" or a "906" casting number. found on 96-2000 GM 350-5.7L L-31 pickup truck motors. Any thing else is something else. Not a direct bolt on by the results are worth th effort. They work very well.
Old Sep 16, 2006 | 01:14 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You have a 305, I think F-bird was mentioning 350 vortec heads, which would lower your CR ratio a tad.
Also, your TPI setup, i'm not sure if you have MAF or SD, MAF should work ok, SD will moan and complain 'cuz "something" is wrong... Then again, a bit of machine work on your current heads might be worth considering.
Old Sep 16, 2006 | 11:47 AM
bert4's Avatar
Car: 1987 Iroc
Engine: 305 T.P.I.
Thanks for the help. I can have the heads redone, I was just looking to see if there was a way to "Upgrade" to something better? I figured since things have to come off I might find something better performing to bolt back on. Any ideas??
italiano67
Dec 11, 2016 09:21 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 07:57 PM
novaderrik
Aug 10, 2015 12:44 PM
