cant stop surging.
Old Sep 20, 2006 | 06:21 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
cant stop surging.
well i got my car to pretty much run great except for the damn surging. when i first start it up or drive alittle ways it surges from 650-750rpms then when i drive it for along time it surges from 500-1000 rpms. Ive set the idle adjusted the iac cleaned the iac and throttle body. All vacuum lines are good ran seafoam from it (pcv vacuum line) put different fuel injector cleaners and it still surges what is causing it to run like junk?
Old Sep 20, 2006 | 03:54 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Could be a fuel pump starting to go out. Also you might get the ignition module tested. My car did that and it was a bad ignition module.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
