Oil capacity
Old Sep 20, 2006 | 04:59 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Oil capacity
How much oil does a 86 305 camaro hold? I can't find it anywhere and i don't have the Owner's manual.
Old Sep 20, 2006 | 06:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Around 4.5 litres.
Old Sep 20, 2006 | 07:14 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
exactly to the full mark on the dip stick....or at least thats what we tell customers.......tao
Old Sep 20, 2006 | 08:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Buy 5 quarts. If that doesn't reach the full mark, you have a problem. If it's too much, you'll have some for when you need to top it up or the next oil change you won't need to buy as much.
"To the full mark" is only good when you have a factory pan. I have a 7 quart pan on my engine and the full mark is too high. 6 quarts in the pan keeps the level below the baffle and away from the crank. I just cut my dipstick tube down so that the full mark on the dipstick reaches down to where I want the oil level.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
