New to TPI .....Help
Old Sep 23, 2006 | 08:18 AM
slowdeath's Avatar
Pardon my ignorance but back in my day (I am really only 41) we had carbuerators.
I bought my son a 1987 IROC with the 5.7 TPI engine. The tranny lost 3rd gear and he blew it up. A friend grabbed a 4 bolt short block with a new Edlebrock performer cam and threw the TPI heads on it. Now for the questions:
1. What RPM is this car supposed to idle at? The original engine had 120K and idle was a bit high (1000) for an auto.
2. Will the computer adjust for the different cam? I am sure that the valve timing is different than the stock.
3. Will the computer adjust for the K&N filters and flowmaster?
4. This electric fan thing on at 225 scares me. Is it worth swapping out the switch for a 200 or 210?
5. What do you guys think of the hypertech thermo chip? I have already installed a 180 thermostat.
Thanks in advance for any help or advice. (This really IS his car, I am just having too much fun hot-rodding again)
Old Sep 23, 2006 | 06:26 PM
slowdeath's Avatar
Anyone??
Old Sep 24, 2006 | 03:03 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
The computer will compensate for fuel, so it should work for the things you listed. The computer cannot compensate Spark Advance (SA) for modifications to the engine. It would probably run a little better if you could make some changes to the chip, but that kind of opens up a can of worms. (I like worms)
Take a look at the DIY-PROM board and read the stickies to get a feel for the things you can do. It really isn't as difficult as it may first appear.
Old Sep 24, 2006 | 11:54 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I think stock idle speed is around 600 in drive and 800 in park. You might try removing and cleaning the throttle body and IAC. Then reset the min air per this article. Timing should be at 6 degrees btdc.
IAC Cleaning https://www.thirdgen.org/forums/tpi/...t=iac+cleaning
Min Air adjustment https://www.thirdgen.org/tpimod2
87 being MAF, it should compensate fine for that cam. I'm still running a stock tune and have much more than a cam.
I wouldn't waste the money on a Hypertech chip. I would seriously consider getting into prom burning as AtomicTruck suggested. That way you can set the primary fan to come on whenever you like. You will also be able to play with the fuel and timing curves. Here is a good place to get the equipment <u>DIY Fuel-Injection Tools:</u><br>Created by an EFI enthusiast for EFI enthusiasts like you! : Moates.Net
Old Sep 25, 2006 | 07:07 AM
slowdeath's Avatar
Thanks to all for the advice.
It is up and running strong but i will give the PROM burning some thought.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
