LG4 Timing
Old Sep 25, 2006 | 07:17 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
LG4 Timing
Ok, i put my fresh rebuilt LG4 in on saturday, and it starts and runs, no leaks, no knocks or pings. But to get it running right I had to turn the distributor counter clockwise to the point were the #8 spark plug wire on the distributor was where the #1 should have been, it doesnt matter to me where the cap is, but what would I have to do to fix it? Pull the distributor, move the oil pump shaft clockwise a smidge and then move the distributor clock wise a smidge also? When I check the timing I made marks every 1/4 turn on the harmonic balancer for setting my roller rockers and I have the timing lead on the #1 spark plug but when I check the timing where it is now the mark for what i beleive is the #8 cylinder is hitting the 0* mark on the tab. If it is not a problem than Im not worried about pulling anything, just want to get some opinions on if the distributor was off a tooth on the gear or not, thanks!
Old Sep 25, 2006 | 06:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like it's one tooth off. But, set the timing with the #1 spark plug, it doesn't matter where the wires are with respect to the cap or engine/car.
RazorN8
Jan 7, 2022 11:44 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
