Signs and Symptoms of TPS
Old Sep 28, 2006 | 06:40 PM
rainfly's Avatar
What are the signs and symptoms of a failed or failing TPS? Do they just die or can they have intermittent failure?
Old Sep 28, 2006 | 10:08 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
They can fail intermittently. It should set off your ses light. I've seen them cause idle, and even transmission problems.
Old Sep 29, 2006 | 12:28 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I just had that happen on my '99 S-10 4.3L Automatic. The CE Light was on and it was banging 1st gear then it got to the point it wouldn't go higher than 10mph at 3000rpm, idle was abnormally high, and wouldn't shift into any other gear.
I used AutoEnginuity's OBDII PC scan tool to scan the ECM.
It indicated a bad TPS, replaced it, cleared the code, and all was back to normal (idle didn't drop to the normal 500rpm until after the test drive.)
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
