What size head bolts
Old Sep 28, 2006 | 10:21 PM
jl2152's Avatar
Car: 88 IROC-Z28
Engine: 5.7 L TPI
Transmission: TH700-R4
I have a stock 88 IROC with a 5.7 where can i look to find out if it the head bolt size and whether or not its a 2 or 4 bolt main.
Old Sep 28, 2006 | 10:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
SBCs all use the same size head bolts. The threads are something like 3/8-16 IIRC, and there are 3 different lengths used. To tell if it's 2 or 4 bolt main, pull the oil pan off and look. If it's stock, chances are that it's 2 bolt, not that it matters.
Old Sep 28, 2006 | 11:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think the head bolts are 7/16"-14 actually.
you definately don't want to pick up bolts from the hardware store, if that's what you're thinking. You need like the grade L9 or better. I think a head bolt kit from mrgasket, or better yet, ARP, would be best.
I wouldn't lose sleep over the 2/4 bolt, that's an old hot rodders fantasy tale.
toronto formula
Nov 10, 2015 06:17 AM
355tpipickup
Aug 25, 2015 12:54 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
