need help!!! building up 305 h.o.
Old Oct 1, 2006 | 09:01 PM
84'fbody's Avatar
any good power adders to a 1984 trans am 305 h.o. Right now it's pretty much stock besides a mallory hei distributor, edlebrock 600 cfm carb, holley intake manifold. Looking to keep the 5.0. gotta work with what I got. Need heads, cam,. But need to know what kinds to buy. Will the heads off a vortec blazer fit?? I have about a grand to do this. Thinkings about nitrious for the track. Is that a bad decision???
Old Oct 1, 2006 | 10:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Exhaust will give you most HP / $ right now. Blow the whole grand on a good exhaust setup. That way you can re-use it with the 350 down the road
cam can be upgraded to a compxe256 with lifters and springs if you like (after the exhaust!)
Old Oct 2, 2006 | 08:46 AM
Damon's Avatar
Agreed, headers and good exhaust are the first things to upgrade.
Vortec heads will physically bolt onto your engine but you'll need a different (Vortec-specific) intake manifold to bolt onto them. Also, you'll have compression issues to deal with as the chambers on 350 Vortec heads are larger than those on your original heads. Lastly, they require self-aligning rockers arms which your current motor doesn't use.
Old Oct 2, 2006 | 08:53 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
forged pistons, steel crank, stainless valves, and a big ask bottle.
Old Oct 5, 2006 | 08:11 PM
84'fbody's Avatar
Will True duel exhaust fit under that car like a h or a x pipe??? go 2.5" or 3". With hooker compt. shorty headers????
Old Oct 5, 2006 | 09:46 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Do you have to pass emissions?
Old Oct 6, 2006 | 06:40 PM
Damon's Avatar
True duals were not something GM had it mind when they designed the 3rd gen. It's not really a cross-member issue but a combination of several things...
The floor pan on the driver's side sits lower than the passenger side and there's really not much room to put 2 individual mufflers under the rear seat floorpan. I've seen it done- sometimes decently, sometimes disasterously, but it's not really the best way to go, in my opinion.
And you don't really need that much exhaust for what you're doing. A set of Hooker shorties and the (included) 3" y-pipe will work fine with a 3" cat (the stock cat is 2-3/4" and will work OK if it's in good shape, as will a 3" straight pipe if emissions are not a concern) leading into a 3" cat-back system (Dynomax makes a good unit for very reasonable money, as do many others).
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
I'llrocya
Feb 2, 2016 11:43 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reborn756
Sep 4, 2015 03:42 AM
