Are my injectors leaking? My test results.
Old Oct 4, 2006 | 05:43 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I just hooked up a fuel pressure tester, I started the engine and shut it off, it read about 40 psi. Then after about 15 minutes it dropped to about 30 psi, then it stays at 28-30 psi for over an hour.
So, are they leaking? Or are they okay?
If they are decent I rather stay with them since I really cannot afford to drop extra money on injectors.
Also, I am running 305 injectors on a 350, how bad is this?
Old Oct 4, 2006 | 06:20 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
That leak down rate is normal, the injectors are fine. You may be running a little lean though. 305 injectors are 19lb, 350 injectors are 22lb. The MAF system will try to compensate while in closed loop, but in open loop (when you first start the engine) you will certainly be lean.
40 psi is a little low, should be 44 psi. Did you remove the vacuum line during the measurement?
Install an AFPR and run ~47 psi and you'll be better off than you are now without changing the injectors.
Old Oct 4, 2006 | 07:59 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
funny how you say I could be running lean, because I am running rich as hell.
I think it was due to the MAF relay, I replaced it today and I think it runs better.
Old Oct 4, 2006 | 09:47 PM
mnorton's Avatar
Engine: 305 LB9 TPI
Hmmm.... I'm not sure what the MAF relay failing would do, but unless you have a modified PROM, I still stand by my previous statements concerning the injectors.
Old Oct 5, 2006 | 05:32 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Well I would get an intermittent code 33, which is for the MAF voltage low, When the SES would come on the car would run like crap. Backfire, rough idle and what not. So I replaced the relay, light hadnt come back as of yet.
bamaboy0323
Sep 3, 2015 06:07 AM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
