305 bore question
Old Oct 5, 2006 | 05:48 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
305 bore question
If a 305 is essentally a bigger 350 with just bigger pistons and different insides, but an identical block, can a 305 be bored over to be a 350 or maybe the 383 that I want. I heard from my father who is a mechanic that its the same engine except for the insides. I really want a 383 to replace my LG4 but if i could bore it that would be great. He isnt sure if its possible so I was just wondering if anyone knows about it.
Old Oct 5, 2006 | 06:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 305 is 3.736" bore, the 350 (and 327) is 4.000" bore. Both are cast such that they have about the same cylinder wall thickness. A safe overbore on either is about .060", so if you add 3.736" and .060", you get 3.796" - meaning if you try to bore a 305 block to 4.000" bore, you'll be about 0.102" short on wall thickness (remember, bore is diameter, so only half comes from each "side" of the cylinder).
If you want a 383, you need a 4" bore block casting. You can put a 3.75" stroke crank in a 305 block, but that is never cost-effective (comes out to 334 cubic inches with a .030" clean-up overbore), being smaller and more expensive than a rebuilt 350.
Old Oct 7, 2006 | 04:39 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I had a friend that said he sleeved his 305 to make it a 350. I had a really hard time believing that, especially because like five7 mentioned you could just buy a 350 at the expense of that much work. I suppose that it's possible, just don't know why you'd bother.
Old Oct 7, 2006 | 05:59 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Your friend is pulling your chain. The only way to get 350 cubes from a 305 is to have a .60 over bore and a 3.875 crank. I have never heard anybody doing that and I don't even know if they could. It would be the biggest waste of money.Almost all 3.875 cranks are expensive because most are forged.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
