stripped oil drain plug
Old Oct 7, 2006 | 02:19 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
i just recently had my oil changed and a few days later i knowticed a few drips coming fromt he plug so i went to tighten it and by my suprise it just easily turned so i was thinking wow they didnt tighten the drain plug so i turned it agian and it got tight then loose right away, so i drained all my oil and took a good look at the drain plug that part it self is fine but the hole in the oil pan apears to be stripped out. do they make a kit to repair this? or whats the best way of fixing it?
Old Oct 7, 2006 | 02:31 PM
killa_b's Avatar
easiest way is to just get a pan saver plug otherwise youll have to oull the oil pan to fix it
Old Oct 7, 2006 | 02:34 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
They make "oversized" oil plug bolts.
Old Oct 7, 2006 | 06:03 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
why not take it back to the place that stripped it out and make them pay for it?
Old Oct 7, 2006 | 06:47 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Obviously the guy notice it didn't snug up and though "Oh ****" and left it hoping it would be ok.
I did an oil change 2 weeks ago and my plug didnt seem to want to snug up and I reacted the exact same way. I will likely have to tap it come next oil change. Hope not though
Making them pay for it would be a hassle. Especially since threads strip from fatigue, no one can really make the threads strip out, they just happen. See this recent thread. https://www.thirdgen.org/forums/tran...ml#post3084713
Old Oct 8, 2006 | 09:15 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
don't re-tap it, you'll end up with metal shavings in the pan. Get the plug saver kit from Advanced Auto Parts for like $4 and be done with it. Don't take it back to the genius the f'd it up either. Chances are that he's going to screw it up worse than he did the first time
Old Oct 8, 2006 | 01:16 PM
killa_b's Avatar
i actually work at an oil change place and they do cover stripped oil pans although stock chevy oil pans are real hard to strip only possible way is to cross thread it and tighten it all the way unlike those pos aluminum pans on most dodge fwd's
Old Oct 8, 2006 | 05:41 PM
Engine: 350 tpi
i took it back there and they said they didnt do it. they said it was moslikly done when i tried to tighten it up. anyways i put a one over in and it still leaked so i tried to tighten it more and it striped agian. I pulled the pan off..... PAIN IN THE REAR! to do.... stupid oil filter. i just welded in a nut. i still need to put the pan back on though. just got to tired and wore out to continue this what i thought would be a small repair of just tightening a bolt!
:edit
im gunna see what i can do with the shop that did it cause ive never had a problem with it before.
1992 Trans Am
May 10, 2023 07:19 PM
anesthes
42
Oct 24, 2015 07:30 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Navy8125
Aug 21, 2015 09:32 AM
