Tranny crossmember bolt hole stripped
Car: 1992 RS
Engine: 406 Stealth Ram
How in the heck do I fix this? No idea how it happened, the bolt felt fine going in, but I had to take it out to make an adjustment. When I took it out, metal pieces came with it. My only idea is to drill the hole out a little larger and rethread it to the next bigger size. Have any of you guys ever had to deal with this? Thanks!
Car: 1992 RS
Dont you need at least some threads left to use a heli-coil? I guess its worth a shot. I'll try it out, hopefully it works.
its really simple, get a 7/16 coarse tap. you can use the reccomended drill size ( 3/8 i think) or in this case you can just run the tap through the existing stripped hole, In this case it works out really good. I have don ethis to all of mine, they all gave up at the same time. Just don't forget some grade 8 7/16 coarse bolts.
Yep, that's what we do, very easy.
Steve
Car: 1989 IROC-Z
Originally posted by RB83L69
Heli-Coil it.
Heli-Coil it.
Car: 1989 IROC-Z
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Same thing happened to me....I think it happens to everybody. I didnt even drill it out. I believe I just used a 7/16" tap to go over the threads and used a 7/16" Grade 8 bolt and washer from the hardware store. I also cut a 1" diameter hole in the side of the subframe so I had room to put a nut on back of the bolt, but I didnt end up needing it as the newly cut threads held good enough. The next time I have to remove the tranny crossmember I'll probably have put a nut on the back of it.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
