Roller Bearing or Hydraulic flat?
Old Oct 12, 2006 | 08:37 AM
Bane's Avatar
Just like the title implies, whats the best lifter for a cam? Are there any advantages to one over the other, what one will last longer?
Old Oct 12, 2006 | 08:52 AM
Damon's Avatar
Any given cam is designed for one or the other- they're a matched set. You can't just change lifter types without changing the cam.
Roller cams offer advantages of higher lift and higher valve acceleration rates than you can get with a flat tappet- that typically equates to more power potential, apples to apples. However, there are offsets to this- cost being one (flat tappets are dirt cheap) and setting up a roller valvetrain to work in the higher RPMs is not always a "throw parts together and turn the key" type of affair.
Roller cams are also easy to break-in on first install (wiping out lobes is rare), where flat tappets require a specific break-in regimen if you want to have your best shot at letting the new cam/lifter live a long and healthy life.
Better? What fits your needs and budget best is what's better. Both have their place.
TX-SleeperC5
Feb 24, 2016 01:34 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Jorlain
Oct 8, 2015 01:57 AM
RyanJB
Sep 14, 2015 03:39 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
