annoying hissing sound when heat is on
Old Oct 15, 2006 | 08:10 PM
liquidrider3214's Avatar
ok so when i turn on my air inside it comes on just fine blows strong but when i switch it to warm or hot air it suddenly makes a really irritating hissing sound, the heat still comes out the vents but it makes a hissing sound almost like air coming out of a small hole exept alot loounder like a pssssssssssssss it stops as soon as i turn the air to cold, car is a 87 z28 anyone know what the hissing noise is it kind of sounds like its coming out were the control unit is and were the radio is
Old Oct 15, 2006 | 08:11 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
the vents are vacuum operated. Sounds like you have a vac leak .
Old Oct 16, 2006 | 03:27 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Old Oct 16, 2006 | 12:28 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
as well.
You're gonna be pulling your radio console out and part of the dash as well. Make sure you get a good harness to replace it with. This is one of those things you don't want to do twice.
Old Oct 17, 2006 | 08:28 PM
4kidsandno$'s Avatar
noise
The problem is a 6 or 9 port vac switch behind the ac/heater control assy.
Old Oct 17, 2006 | 08:46 PM
heat console and radio are out now what? what do i look for?
Old Oct 18, 2006 | 05:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A series of mulit-colored vac lines going into the pass side of the HVAC controls. The switch itself is prone to leaking, so before replacing the lines, check the switch.
JamesC
Old Oct 18, 2006 | 06:53 PM
thanks for all the help everyone but which side is the pass side?
Old Oct 18, 2006 | 08:01 PM
JamesC's Avatar
Passenger.
JamesC
Old Oct 18, 2006 | 08:26 PM
wow that made me feel really stupid thanks
Old Oct 19, 2006 | 05:15 AM
JamesC's Avatar
Brain fart--we all have them.
JamesC
GTAman
Jul 3, 2024 07:29 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
bryan623
Sep 19, 2015 10:13 AM
84redta
Sep 19, 2015 09:58 AM
BLK87Z
Sep 18, 2015 11:29 PM
