replacing fuel pump
Car: 1988 camaro conv.
Engine: 305tbi
Axle/Gears: dont know yet
replacing fuel pump
CAR WONT START,CRANKS OVER NO FUEL GOING TO THE CARB.NO SOUND OF A FUEL PUMP RUNNING IN THE TANK WITH KEY TURNED.LOOKED AT ALL FUSES THEY LOOK GOOD.HOW DO I CHECK THE FUEL PUMP RELAY UNDER THE HOOD.AND ANYBODY KNOW HOW TO REPLACE THE THE FUEL PUMP IN THE TANK.ANY HELP WOULD BE APPRECIATED.THANKS
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Well, its not a carb its a throttle body
There is a way to put 12v to the fuel pump, on the diagnostic terminal ( dont remeber which) someone will chime in, if it primes its wiring or relay.
To replace it, as i remeber its taking out the exhaust, lowering the rear end. disconnecting fillter tube, and fuel lines and electrical
and of course the straps
Im sure someone who has more knowledge then i and will fill you in
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
replaced mine in half hour by pulling back carpet and cutting access panel with grinder in sheet metal......................shoot me
behind rear seat, i have no rear seat , but, its dead center on hump b4 t top storage bin...............just make sure you wear eye protection and watch cut, dont press too hard or youll cut gas lines, these need to be cut anyways but with sparks in the mix it could be 4th of july ..............make sure you use cutting wheel and not grinding wheel, cutting wheel is very thin.........
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
get under the car and disconnect the fuel pump wiring harness from where it comes out of behind the rear seat. Test for power with a test light when someone turns the key on. One of the wires should light up for a couple seconds to prime. If not you have an electrical problem.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
1st - check the fuse that is beside the battery - there is a wire pair that dead ends into a fuse that's tucked under the fenderwell just beside the battery.
2nd - get a fuel pump relay from auto parts store for that car - pop the hood, locate ALL relays that match it, swap them one by one, and see if any of the swaps change things.
3rd - find the Oil Pressure Sending Unit - should be located above oil filter - three wire connector to it - unplug connector and jump two of the wires (you'll have to look into Haynes to see which two colors, I don't remember) - if that makes fuel pump run, then you need a new OPSU.
4th - turn key on, crawl under rear and find the plug going to the fuel pump - there is a connector up in the rear hump just in front of the axle/differential - unplug it and test for current. No current means a) one of the above still bad, or b) break in that wire between OPSU and that connector - test continuity between OPSU and that connector with a long wire.
5th - all above failed - fuel pump is dead - replace.
Engine: 305tbi
removing fuel pump
I CUT A 4INCH SQUARE BEHIND THE HUMP IN THE FLOOR.FUEL TANK LINES AND WIRES ARE RIGHT THERE.DO I NEED TO CUT ALL THE STEEL LINES AT THE PUMP OPENING TO PULL THIS ALL OUT.HAVENT CUT ANYTHING YET,NOT SURE HOW TO PULL IT APART.THANKS FOR ALL THE REPLYS.
behind the hump? you need to be dead center of hump, the pump is held in with a locking ring on top of tank, yes youll need to cut lines and redo with rubber fuel line, i used a small plumbers pipe cutter..........
Engine: 305tbi
fuel pump
Wow this is a bad deal when these pumps stop working.Will cut the lines and pull this pump out.thanks for everybody help.
92camaroJoe
Aug 13, 2015 06:07 AM
