83 factory ram air
83 factory ram air
Hi,
I just picked up an 83 TA with Factory ram air. I have a few questions for whomever has a similiar setup.
1) Their seems to be a long thin plastic hose that was in the back seat that I think hooks somehow to the ram air. Does anyone know where theis long thin black tube goes under the hood or better yet does anyone have a picture of their setup?
2) how does it work? I know it opens when you are on the throttle but how can i test it to see if it works? I have the factory service manual but I don't see anything on this subject. There seems to be a solenoid, a black tube, vacuum hoses, etc. that are all hooked to it.
Any help would be appreciated.
Thanks!
Thanks!
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I remember a little of that setup- only available on carbureted cars in the early years. The rear-facing hood scoop, offset to the driver's side like later Formula cars, had a round outlet near the middle of the hood, just to the driver's side that mated up with the (special) top lid of the factory air cleaner that had a matching round or oval hole in the top. There was a short rubber boot that sealed the two of them together when the hood was closed. Sorry, that's all I remember about that setup.
I beleive there was a flapper somewhere (in the scoop itself?) that was only open when you were near WOT. No idea if it was electrically or vacuum operated.
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
