fule pump running while engine off
Old Oct 22, 2006 | 11:00 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Just got this new pump installed a week ago. No problems. Yeasterday went driving around all day without problems. Last night I went out to the car just to look at it (fresh wax yesterday) and heard my fuel pump motor running. Opened gas cap and felt constant pressure coming out. I started the car and shut it off...pump still running and not shutting down. Pulled the relay. Still running! I finally just d/c's the neg batt cable and decided to figure it out this morning.
The only other thing I did yesterday was look at myfuse panel to attempt wiring my seat motor. I pulled the driver side kick panel off and looekd at the wiring. (Maybe I just looked at it wrong )
I d/c's one connector (think it was for the door locks/window) and plugged it back up. Then I pulled some big black relay out of the space in the sheet metal behind the kick panel thats held in with a piece of black sticky stuff but didnt disconnect anything before putting it back where it supposed to go.
I've heard the fuel pump ground is there somewhere. Maybe I messed something up in that area.....thats where the fuel pump ground is right?
I couldnt see any loose wires or anything. What have I done??????
Old Oct 22, 2006 | 11:54 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Unplug the fuel pump oil pressure switch just above the oil filter.
Old Oct 22, 2006 | 01:30 PM
Well i did just replace the oil switch, but that was before the new fuel pump.
Is this a common solution to a common problem, or is unplugging that connector a means to diagnose?
What gives? You think it may be the oil pressure relay to to the pump?
Old Oct 22, 2006 | 01:41 PM
Engine: 350 4BBL
If it's wired like an '88 the switch works in parallel with the relay. Either one can turn the pump on. If you unplugged the F/P relay and the pump was still running, it ain't the relay. That only leaves the switch and it's wiring. Are you sure you unplugged the F/P relay? My 88 has 3 relays in a row that look similar.
Old Oct 22, 2006 | 04:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
A bad OPSU will make the pump run constantly - been there done that. It'll kill the battery after about 3-4 days without starting car. Replace the OPSU again.
Old Oct 23, 2006 | 12:40 PM
To the first question, yes I made sure i pulled the fuel pump relay. Looked in the wiring diagrams to make sure I got the one with wires red, org, grn/wht, blk, gry.
I see your reasoning now.....must be the opsu or the relay there.
I'll replace it with a delco.
Thanks alot!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
