fuel lines
Old Oct 23, 2006 | 01:25 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
fuel lines
The fuel lines on my car run to the passenger side. If I'm using tpi could I just bend the lines on the fuel rail to the passenger side to hook up to the fuel lines on the body. My sending unit is just like the one that came out except the main feed line has a an fitting. the other one was just connected with rubber hose and a clamp. where does the fuel filter hook up at. can i just connect it here where the sending unit line comes out?
Old Oct 25, 2006 | 07:47 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
bump
Old Oct 25, 2006 | 03:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The EFI fuel filter is located in front of the rear axle. You should not use rubber hose with hose clamps on any of the fuel line after the fuel pump. If possible, the best choice, in my opinion, would be to get factory EFI lines from the tank on up.
Old Oct 25, 2006 | 03:16 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
The lines on the body are steel. The rubber hose I spoke of is only about 5" long. I was planning on getting a compression fitting to put on the steel line that is already there. I just needed to know where the filter went. Also could I bend the lines on the fuel rail to point to the passenger side? I plan on getting braided steel hose for the fuel rail to hook to the lines ran under the body.
Old Oct 25, 2006 | 03:58 PM
five7kid's Avatar
I don't know about bending the fuel rail lines. I don't think I'd do it.
I'd rather cut the lines before the point where they go over the transmission and continue them up along the driver's side frame rail like the EFI cars had. Cooler, shorter routing, would connect to the fuel rail lines as intended, etc.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
