RHS vortec
Old Oct 25, 2006 | 12:28 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
RHS vortec
They are actually publishing the flow numbers for the RHS vortec heads. For some reason they flowed them with a 4.200 bore. I wonder how this reflects to smaller bores. For some reason they put in big block gasket numbers which is odd.
RHS™ - Pro Torker™ Chevy Small Block Racing Heads
Old Oct 25, 2006 | 06:29 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
On a smaller bore, the numbers will be lower. I hate shaddy stuff like this. It makes other companies do the same thing to compete, and we loose out on the end.
Old Oct 26, 2006 | 08:56 AM
shaggy56's Avatar
Car: 71 Nova
All I can say is at least they are being honest about what bore they tested the heads at so its really not shady. Almost every other head manufacture doesnt even report what bore they test their heads with so that is even more shady.
Old Oct 26, 2006 | 01:33 PM
shaggy56's Avatar
Car: 71 Nova
Someone at an independent shop said they flowed five sets and they flowed in the low 240s which still sounds pretty good to me.
Old Oct 26, 2006 | 03:48 PM
11 Flat's Avatar
I have only Flowed one set of RHS/Pro-topline vortec heads ( I prefer the bow-tie vortec)
They flowed 244 at .550 and in the high 180's for exhaust
This is going off memory, I'll see if I can dig the sheet up
Old Oct 26, 2006 | 06:06 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
You are correct there.
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
