miss at idle only
Old Oct 31, 2006 | 01:30 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
miss at idle only
I have an 87 TA 305 TPI. I have a miss at idle that is very confusing. The car will idle fine but every couple minutes it will have a quick stumble in the idle, it is just enough where you can feel that it stumbled. I have had the pickup coil replaced ( AC Delco) & had the module checked at autozone (the old one Accel went bad replaced with original Ac Delco unit). I have also replaced the dist. cap & rotor with new msd & the wires are new taylor wires. The plugs are new Ac Delco. Are there any usual causes for this symtom?
Old Oct 31, 2006 | 01:35 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
dirty IAC?
Old Nov 1, 2006 | 10:25 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
As in the engine misses 1 single event or actually coughs through 3-5 strokes?
A tiny exhaust, or maybe even a tinier intake leak may cause something of this nature.
If it only misses one event every couple minutes, I don't see any real problem. The universe is not a perfect place. An extended symptom may indicate something is wrong, and I think the leaks would be a good place to start.
Old Nov 3, 2006 | 11:51 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Could it maybe be a small vacuum leak? Isn't there a way to check for these with a propane torch(benzomatic)? Does anyone know how?
eightsixseven
Dec 16, 2024 01:50 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
86CamaroDan
Sep 29, 2015 10:08 PM
beast94
Aug 20, 2015 06:44 AM
