305 engine components
Old Nov 4, 2006 | 04:34 PM
bilyrocker33's Avatar
Car: 1985 Sport Coupe Camaro
Engine: 305 4 Barrel
Transmission: Stock
Axle/Gears: Stock
so ive been looking around here and from what i have read i have concluded that these would get my engine pumpin fast and hard... but im not sure, lol so please if i did put this in my stock 305 would it make it faster?
650 cam
4.000" crank
and bored over 0.030
or
650 cam
4.000" crank
and bored over 0.040
or
650 cam
4.000" crank
and bored over 0.060
Old Nov 4, 2006 | 04:40 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Boring larger doesn't make more power. Just bore out as much as needed to clean up the cylinder walls.
Old Nov 4, 2006 | 04:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You're not going to fit a 4" crank in a 305, and if you went through all the trouble of shoe horning it in (if it's even possible, which I don't think it is), that'd be among the stupidest things known to man.
What's a 650 cam?
I suggest you go onto the FAQ board and read all the writeups on making a 305 faster. Also, consider the obvious, different block.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
