starter problem t5
Car: 85 camaro z28
Transmission: auto to manaul
starter problem t5
almost finished the t5 swap, the starter isnt touching the flywheel. it did once but thats it. its a t5 start and flywheel. heres a dump question, did i put the flywheel on backwards? cant thing wat else could be the problem?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you mean the starter is too far backwards, or too far outwards, or...?
Is it the stock starter from your 700R4 application? Straight bolt pattern?
What size flywheel is it? The 153 tooth right?
92camaroJoe
Aug 13, 2015 06:07 AM
db057
Aug 11, 2015 10:11 PM
