Push Rod ?
Old Nov 5, 2006 | 01:12 PM
zrated57's Avatar
Push Rod ?
Which size push rods do I need for a retro fit 383 stroker? please provide part #
Old Nov 5, 2006 | 01:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Measure and see.
Old Nov 5, 2006 | 07:22 PM
Damon's Avatar
Depends on whose lifters you're using. The manufacturer should be able to give you a rough starting point but that's still no substitute for measuring.
Old Nov 5, 2006 | 07:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you are changing cams, heads, rocker arms and any machining you need to measure. No other way.
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
