LT4 springs question...
Old Nov 5, 2006 | 08:57 PM
8989's Avatar
Car: 89 Camaro IROCZ
Engine: stock 350
Transmission: automatic
How big of a lift can these springs handle? These supposedly came on my heads I got last year, GM pt no. 12556463. I'm also planning on putting on the LT4 hotcam and a a TPiS Miniram intake. Would this cam be ok with on the stock 1.5 rocker?
Old Nov 6, 2006 | 08:28 AM
8989's Avatar
Engine: stock 350
top
Old Nov 6, 2006 | 10:02 AM
Vader's Avatar
They work to at least 0.530" lifts. They don't quite fit the stock 1¼" spring pockets. Mine measured closer to 1.280" OD.
With 1.5:1 rockers, the LT4 "Hot" cam produces a net lift of around 0.493"
Old Nov 6, 2006 | 11:58 AM
8989's Avatar
Engine: stock 350
So you are saying that they will work on my 113 Corvette heads with the oem LT4 springs with no problems?
I'm definately gonna change to a MiniRam once I figure out where I can get it for cheap...
As for now, my motor is totally stock, but just with Corvette L98 aluminum heads + those LT4 springs...
Also with a .493 lift, could there be possible piston-valve interference?
How much work is needed to change just the cam and intake?
Thanks a lot.
Old Nov 6, 2006 | 08:03 PM
8989's Avatar
Engine: stock 350
top
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Dragonsys
Sep 25, 2015 03:51 PM
