oil on firewall after intake gasket install
Old Oct 25, 2006 | 09:53 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I just finished the intake gasket replacement on my 89 350 GTA. My biggest concern is that after a short drive I found oil splattered on the firewall. It's around the distributor area from about the master cylinder to the coil up to the top of the firewall. I didn't see anything while it was idling.
I'm obviously hoping it's not the rear intake seal since the job was tough for me.
The minor problem is the car seems kinda flat on acceleration (won't chirp the tires off the line anymore or from the 1-2 shift) I also installed a TPIS regulator but I did set it to 47 psi at idle with the line disconnected. I also installed new accel 21 psi injectors- 3 of the factory ones went bad.
Thanks in advance for any advice.
Old Oct 26, 2006 | 03:06 AM
ede's Avatar
ede
i'd say you have a leak at the china wall
Old Oct 26, 2006 | 03:21 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
how long did you wait to fire the motor after you sealed the intake? shoulda been at least a couple hours.. also, what did you seal the front and rear of the manifold with? did you use silicone? the junk rubber gaskets are a waste of money..
Old Oct 26, 2006 | 05:37 AM
Car: 89 GTA
Transmission: 7004R
I used a felpro gasket set, it didn't have a rubber gasket for the front and rear, it said to use the black rtv it came with.
I waited days before starting it due to other problems I ran into.
I guess the china wall is the rear seal of the intake?
Old Oct 26, 2006 | 07:00 AM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
Could be leaking at the Distributor gasket to. Make sure timing is set correctly and that the Distributor hold down is on the shoulder of the distributor and that it is tight...
Old Oct 26, 2006 | 07:22 AM
Car: 89 GTA
Transmission: 7004R
thanks, I did check that last night. I pulled the distributor and checked the gasket there and made sure the hold down bracket was good and tight, but the problem is still there.
Old Oct 26, 2006 | 09:02 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Also, make sure your OPSU (oil pressure sending unit) is snug. If you don't have one there, I hope you have a pipe plug in the hole.
Old Nov 6, 2006 | 08:29 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
what was the outcome of this as i have the same issue.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
