car is having a coolant leak!!
Old Nov 8, 2006 | 07:33 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i was driving the car to day and i saw smoke coming from my hood. is leaking coolant onto something hot like an exhaust pipe. it drip very fast right by the oil filter houseing area. but when the car is at operating temp it stop driping and smokeing what you think it is.
Old Nov 9, 2006 | 06:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely is the intake manifold leaking from the driver's side back corner. Also possible is head gasket, but less likely. Could also be a cracked head or block, or leaking expansion (freeze) plug.
I had a leak from an exhaust manifold bolt hole, of all things. I had headers on, changed from 3/4" long bolts to 1", and the rear one punched out the back of the bolt hole into the coolant passage. Leaked about like what you are describing, but mine is the only one I recall ever hearing about.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
