383 stroker /zz4 crate motor
Old Nov 9, 2006 | 07:50 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Hey guys - I haven't been on this board in about a year, lol.
Well, I blew the bottom end of my ZZ4 (50K miles) and there is enough damage that i am seriously considering going with a 383 stroker.
Most people recommend Eagle kits, and I don't have an unlimited budget, so I was looking into what additional costs there will be.
The car is already beefed up, and I have a Super Ram intake and a Comp cam above, so I am looking to make over 400 HP with this setup.
Comments, suggestions?
Old Nov 9, 2006 | 07:59 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I'm going through a 383 build right now. I bought a kit from CNC Motorsports. Good guys to deal with. 5.7 H-beams,forged crank,srp forged flat tops. If your block is good,Clearance pan rails for stroke,small base circle cam,new oil pan or BFH on stock pan etc. I bought an internally balanced assembly from them but I am having my machinest check it with the HB and the FW. If you plan on building it yourself,be sure to check all of your clearances. The Eagle kits are good kits for the money,but My machinest is "massaging" some of the rods due to clearance issues. If you go for it,good luck on the build
Old Nov 10, 2006 | 01:25 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Sorry to hear that. I understand you wanting more cubes go for it.Eagle assemblys are good.I have seen alot of guys use them.400hp out of a 383 is a joke. Pocket port the zz4 heads and run a cam in the 215-224 dur. and your there.
Old Nov 10, 2006 | 03:50 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
no $hit. just pay attention to the clearances on the pan rail, and double check everything or you'll be pulling it all out again. otherwise, it'll live a long and happy life.
Old Nov 17, 2006 | 08:29 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Damn, you blew your ZZ4 bottom end? How'd you do that? Kinda makes me worry. I've got the crate engine with about 25k on it now. I hope it lasts me past 50k miles...
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
