TBI 305 heads vs LB9 heads
Old Nov 14, 2006 | 09:08 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Can anyone tell me what the difference between the 305 LO3 TBI heads and the LB9 305 TPI heads. They have two different casting numbers and when I look them up all it comes back is that they were used from 87 - 95 305. The casting number for the TBI head is 10159551 and the LB9 head is 10159553.
Old Nov 14, 2006 | 09:33 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have looked into this in the past
do not use the tbi heads, unless your power band is under 4k
it has to do with the swirl port in the tbi heads that gives them good power of the hit but chokes the engine in the higher rpm range.
You will get some detailed reasons from some of the other members and that is going to help you or do a search like I did.
Bottom line- do not use Tbi heads
Old Nov 14, 2006 | 09:58 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I did a swap from TBI to TPI on my 92 Camaro. I know the TBI motors had the peanut cam. I just wanted to know what made the heads different. I know the block and internals except for the cam was all the same.
Old Nov 14, 2006 | 10:31 AM
jamon8's Avatar
Engine: 350 tpi
swirl port intake chambers
Old Nov 14, 2006 | 10:51 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Originally Posted by DerekKraese
Can anyone tell me what the difference between the 305 LO3 TBI heads and the LB9 305 TPI heads? ...... The casting number for the TBI head is 10159551 and the LB9 head is 10159553.
Those numbers look like GM part numbers, not casting numbers.
Differences between the heads, along with head flow numbers, are shown here:
https://www.thirdgen.org/forums/tbi/...-headflow.html
Old Nov 14, 2006 | 11:46 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
OK thanks
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
