Manley or Eagle H beams ?
Old Nov 9, 2006 | 12:30 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Well just wondering which is the better out of the two Makeing all things equal ...like the same 190'000 AFR studs ... the eagle looks to be cheaper by about 50 bucks or so .... Is this for a reason >?
also the Eagle has more advertised processes to them like degaussing for less impraties , etc.
Old Nov 9, 2006 | 07:40 PM
EvilCartman's Avatar
Car: '82 Z28
Not sure which is better but the Eagles I have look like a really nice part. Got them for a great price at cnc-motorsports.com
Old Nov 9, 2006 | 11:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm running the Eagle H's No problem in my 383
Old Nov 10, 2006 | 12:49 AM
sixpackmtrspts's Avatar
the differeance is the manleys are made in usa, the eagles are imported.
Old Nov 10, 2006 | 02:02 AM
11 Flat's Avatar
I like the manleys better....
I have used the manleys in some high hp motors [sb/bbc]and never had a problem
Old Nov 10, 2006 | 10:47 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Any reasons we should know of?
Old Nov 10, 2006 | 11:00 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
both are very GOOD rods so go with the better price.
Old Nov 10, 2006 | 12:59 PM
for a street engine the eagles are more than enough, in a race engine id never even consider them.
Old Nov 10, 2006 | 03:20 PM
11 Flat's Avatar
I have not used the eagle or any of the other knock off brands in a while....
But the ones I did use, I had to do some prep to them. Pin clearance different from one to another, Big end sizing, Caps a little off on alignment, weight differences from one rod to another..etc
Since I have not used them in a while I cant remark on there quality now???
But for what it sounds like the poster is going to be doing??? It doesn’t really matter. Just make sure who ever is doing your machine work checks them out
Old Nov 12, 2006 | 04:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I pan on useing them in a T62 turbocharged L-98 . At first I am only putting 6ish psi to it ... then after about 15 .... for around 650 hp. I remeber hearing abotu that Eagle import ... It kinda turned me off of them . SO you figure it will be an either or thing eh ? If there is any question that one will be better suited over the other ( ie , weight ... material needing to be removed on one , but not the other ) I would like to know. The differeance is negledgable.
Old Nov 13, 2006 | 11:18 PM
for that hp level i woundt use either the eagle or the manley, the manleys are only rated to 700 as it is.
Old Nov 14, 2006 | 12:15 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
From what I researched 650hp on the eagle rods should be fine, maybe order them with the ARP L-19 bolt upgrade if your really worried about strength.
Old Nov 14, 2006 | 01:38 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
thanx a bunch guys . Yeah I think the manley rateing is lowers due to the lesser bolts ( 190'000) vs the higher ones as an optioned offered with the other brand
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
327IROC85
Sep 23, 2015 12:11 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
