emissions help
Old Nov 15, 2006 | 12:40 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
emissions help
my camaro (1987 carburated 305) is running extremely rich (smoking black), has soggy throtle response, and gets like 10mpg. from some of my research this may have been as a result of the previous owner messing up the emissions system. i have no cat and i may be missing an o2 sensor or sometihng. could the messed up emissions system be causing my all of my problems?? and if so, how do i fix it?? thanks for your help.
Old Nov 15, 2006 | 04:29 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
it doesn't sound like emmision problems to me,sounds more like a screwed up carb flooding.i don't have my o2 senser hooked up and nothing changed on mine.see if y9ou can get another carb off someone and try that
Old Nov 15, 2006 | 04:41 PM
impaled's Avatar
so you lost your o2 sensor and it runs fine???? then do you think that it could be my choke? cause that was next to check out on my list.
Old Nov 15, 2006 | 04:44 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
thats probly it.my o2 senser is there but no wire hooked to it,car runs mint.take your choke and clamp it open with a close pin or some wire.i have no choke on my car either,never liked them.3 pumps in the morn and ready to start
Last edited by Z28er; Nov 15, 2006 at 04:45 PM. Reason: spelled choke wrong hahaha
Old Nov 15, 2006 | 05:18 PM
impaled's Avatar
this may sound kinda dumb, but are your A.I.R. system/accessories hooked up???
Old Nov 15, 2006 | 05:46 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
whats A.I.R? i disconected all my polution gear and emmisions stuff when i had the motor out.
Old Nov 18, 2006 | 01:05 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
you got a carb problem
Old Nov 18, 2006 | 01:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ok fellas, Z28er lives in Canada. He probably has a non-cc carb. He can do whatever he wants and it'll run peachy (haha, jealous much guys? )
Impaled - what carb are you running? If it's the stock computer controlled setup, your symptoms scream no O2 sensor, now that you've admitted that, get 'er fixed! Then look into choke.
Getting any error codes?
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
