No start 90 RS
Old Nov 16, 2006 | 05:54 PM
tpoch845's Avatar
Car: 92 'bird
Transmission: 700r4, T5 in the garage
No start 90 RS
I've got a 90 rs with the 2.8MPI and no start. I can smell gas and I have checked spark, and motor turns over, but no fire. I'm thinking timing. I just bought the car, and I plan on swapping the motor with the SB that I built for my Cutlass in the spring, but I'd like to get the car running for the winter. I plan on pulling the timing cover this weekend. What are the chances that its not the timing, but rather the VATS? I'm pretty sure that the guy I bought it from gave me the original key...please help.
Thanks guys!
Old Nov 16, 2006 | 07:02 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what are your fuel pressure readings? Will it start with starting fluid? what makes you suspect the timing? What is it currently set at?
Old Nov 16, 2006 | 07:08 PM
tpoch845's Avatar
Car: 92 'bird
The guy i bought it from muttered something about timing. I have fuel, I have spark, that leaves air or timing. Right? I dont know much about all of the electronics...this is the newest car that Ive ever worked on. I havent had much time with it yet. Im gonna pull out the timing light on Sat, but Im just trying to gather info on things to look for. I would like to eliminate VATS as a fault. I also plan on the paper clip trick that I learned here.
Old Nov 16, 2006 | 07:42 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Your probably goin to want to start with all the basics which it looks like you already covered some of that.... It may be a long shot but you should take a quick compression check..... Maybe it got washed down with fuel real bad and wont fire cause of that...... A lot is going to depend on what the other guy did before you... Was the car running when you bought it? If it was running then I would say disregard my previous statement.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
