1.6 rockers, or 1.7's? LT1
Old Nov 17, 2006 | 02:27 PM
nascapper.com's Avatar
Gunna buy a set of roller rockers for my LT1. I have ported heads, headers, pcmforless chip tune, stock cam, stock valve train for now.... lt1 is in a 4x4 truck. anyways, Ive seen the 1.6 self aligning rockers, and that would up the lift on the stock cam to about .477 intake, and .489 on the exhaust, ive read that .490 is about tops for stock springs. Should i get a set? Then i was thinking that if i was to buy springs as well maybe ill get a set of 1.7's? So the question is, can i use 1.7's if i get the right valve springs on this motor? THanks!
nascapper.com
Old Nov 18, 2006 | 12:45 PM
Vader's Avatar
$50 for factory LT4 springs, retainers, and titanium caps. Good to 0.525" lifts at a minmum. Seems like an easy choice - Was for me. Then you can go with whatever cam you want, or rocker combination. The stock rockers really aren't up to the task, and aluminum rockers have less long-term durability. Ideally, the Comp 1417s would be a good choice.
Old Nov 22, 2006 | 10:08 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
50 bucks for the entire package ? Where, Vader ? (need some springs so I can swap in a LT1 cam in my LO3 heads)
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
