If valve lash is off, will it make engine run rough?
Old Nov 12, 2006 | 09:26 PM
MetalliCamaro68's Avatar
I have never set the valve lash. From what I have read, you start the car with the valve cover off. Then one by one, back off the adjustment nut until it clacks then tighten it til it stops clacking, then 1/4 more turn. Right?
Once this is done, will it make a rough running engine smooth out? There are only like 200 miles since a new cam install by someone else. Could valves get out of adjustment that quick?
Thank you.
Old Nov 13, 2006 | 12:29 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
I'm not really sure if your rough situation is caused by the lack of adjustment on the rockers... However, I would definitely adjust them soon. A new cam and lifters will "break-in" and need adjustment. This situation is greater if you have other new parts like springs...
Old Nov 23, 2006 | 01:29 AM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Im pretty sure if valve lash is way way off it will make the engine run very rough
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
