quick compression question
Old Nov 21, 2006 | 01:17 PM
sLoW'n'StEaDy's Avatar
compression question 64cc vs. 76cc
OK, the piston/rod setup i have will make 9.5:1 compression with 64CC heads. What will the compression be with 76CC heads?
Old Nov 21, 2006 | 01:57 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Low, I'd say around 8.3:1. You'd only really want that low compression if you were running boost.
Old Nov 21, 2006 | 02:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
play around with the calc on Keith blacks website.
Old Nov 21, 2006 | 02:41 PM
OK, low is what i want
also too much info i dont know is needed for the calculator. I was lookin for around 8.5:1, so what i have will ork fine.
Thanks,
Keith
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
