Timing Chain part number
Old Nov 22, 2006 | 04:46 PM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
Ive been looking on Summit Racing and havent found a timing chain that will work for a roller cam for my Lo3. I want to get a true dobule roller timing chain. So if anyone can help that would be great. This is for a 92 RS Lo3 TBI engine that all 100% stock with 100k miles.
I did also try the search button without luck.
Old Nov 22, 2006 | 04:59 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
SUM-G6601
Old Nov 22, 2006 | 05:11 PM
So do you need to buy the roller torrington bearing separate?
Old Nov 22, 2006 | 08:40 PM
Damon's Avatar
I don't know about the Summit ones, but here's one of the best chain sets available for a factory roller-cam motor like your LO3:
http://www.sdpc2000.com/catalog/3520...-Chain-Kit.htm
The price is reasonable and the quality is way above your stock chain. Fit is perfect- a true bolt-in replacement with no fitment issues whatsoever. No block or timing chain cover clearance issues.
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
MY87LT
Aug 17, 2015 08:43 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
