belts and pullys dont stop squeaking
Old Nov 23, 2006 | 11:21 AM
crazyL's Avatar
Car: 85 T/A
sorry i didnt know where to put this!! well i keep replacing the belts and the stoping stops for a lil but within a few days it gets back to squeaking non stop. ANyone know what to do.
Old Nov 23, 2006 | 02:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Remove all pulleys (v-belts i'm assuming). Fire up the car (briefly!), and make sure there's no squeal.
Then put on just the water pump pulley, fire up again, verify no squeal.
Rinse and repeat with all belts, to figure out which one is causing the sound.
Could be you're leaving it too loose, or too tight, or one accessory is seized. The air pump is the common one to seize.
Old Nov 23, 2006 | 08:25 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
most likely tensioner
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
