o2 sensor
Old Nov 23, 2006 | 12:03 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
o2 sensor
i have a 1987 carburated 305, and i was wondering how many o2 sensors that it has and where they are at. if there are multiple i then believe that i am missing one. this would explain why my car is running rich and kinda dumb.
thanks.
if you feel that this was posted in the wrong area,please let me know where it should be reposted at
Old Nov 23, 2006 | 01:16 PM
deadtrend1's Avatar
you have 1 02 sensor provided you still are using the Computer controlled carb and factory style headers. It will be in the drivers side exhaust collector, screwed into the pipe with a single wire comming off of it.
Old Nov 23, 2006 | 02:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
should have a purple wire (single) coming off it.
If you're getting a check engine light, and it corresponds to O2 sensor, then indeed something is amiss with that.
Old Nov 23, 2006 | 04:34 PM
impaled's Avatar
no check engine light. my camaro is running rich and i was mainly wondering if there was also an o2 sensor behind the cat and if it had been taken out by the previous owner with the cat (someone told me that some cars had two), because i know that there is no sensor after the header. i am glad to know that he did not mess that up. thanks for your help
Old Nov 23, 2006 | 04:45 PM
deadtrend1's Avatar
Computer controlled F-Bodys used a single, 1 wire, non heated, o2 sensor until and including 1992
to go a little further:
-1993 used two, 1 wire, non heated O2 sensors
-1994 and 1995 used two, 4 wire, heated o2 sensors. 1 on each side pre cat
-1996 up used four, 4 wire, heated O2 sensors to comply with OBDII (2 catalytic converters, 1 before each cat, and 1 after each).
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
