Compression ratio from 10.1 to...?
Old Nov 25, 2006 | 08:33 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
If an engine with a factory 10.1:1 compression with a 66.67cc combustion chamber were replaced with heads with a 72cc chamber, what would the resulting compression ratio be? (swapping stock LS1 heads with Patriot Stage II 6.0 heads) thanks!
Old Nov 25, 2006 | 08:56 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
~9.5 i believe. are you going to boost it?
Old Nov 25, 2006 | 08:58 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yea. Going with steel crank, aftermarket rods, forged pistons, etc and 10-12 psi. Planned, at least.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
