alright well here we go
Old Nov 26, 2006 | 10:00 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
well last night my smog pump seized up like 3 weeks ago my cat was glowing bright red i think these tie into each other but the worst part of it all is that i had coolant coming out of the smog pump lines, no word of a lie. Now i'm stooked and a little P****D off how can i check for a blown head gasket without taking the heads off and has anyone else even heard anything like this b4.
Old Nov 27, 2006 | 03:28 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Well, head gaskets usually blow OUT, so look around the perimeter of your heads for either burst out gasket material, or large areas of burned nasty death. Either one should tell you what you need to know.
Old Nov 27, 2006 | 03:28 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
would a compression test basically tell u if u have a blown head gasket or is it possible that i got something else either hooked up wrong.
Old Nov 27, 2006 | 04:38 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
A compression test will narrow down the possibilities. If you have way low compression in one or two cylinders then you MAY have a blown head gasket. You also could have lost a compression ring, bent a valve, If its a head gasket most shops can do a dye test to see if you have compression in the coolant. This would indicate a head gasket or cracked head. Is it running badly/hot? A head gasket will usually be accompanied by one of these problems.
Old Nov 27, 2006 | 04:56 PM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
Pressure test cooling system
You can get a tool that will pressure test the cooling system. It connects in place of the radiator cap. You pump it up to 15-16 lbs and look / listen for leaks if it does not hold pressure. You could potentially see bubbles or hear hissing at the block / head surface. Another indication of a blown head gasket / cracked head would be coolant in the oil. Drain the pan and look for coolant...... Best of luck
88rscamar0
Sep 23, 2015 09:08 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
un4givin89
Sep 23, 2001 10:41 PM
dtpmike
May 1, 2001 12:32 AM
