Mystery fluid
Old Nov 25, 2006 | 01:16 PM
xbcrguy182x's Avatar
Mystery fluid
Hey everyone! Well ever since I had my car, I have been wondering about mystery fluid on some component in front of the engine. Its a 2.8l v6. Heres a picture...Its the puddle on that circle thing. Anyone know what that is? You can see its also dripping...I believe its coolant. But i couldnt identify the fluid sitting on top of the circle thing. Any ideas? Thanks.
Old Nov 25, 2006 | 02:53 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Taste it
Seriously, I don't know if it's a good thing that I can identify fluid via taste but I guess it has it's perks.
Are those AC lines above it? Condensation maybe?
Old Nov 25, 2006 | 04:40 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
I would go with either coolant or power steering fluid, but its difficult to tell from the picture.
Old Nov 25, 2006 | 04:48 PM
Well, i took a paper towel and dried up the area and I noticed the towel was all black(grease?) with a light green fluid. So its possibly coolant... I know im leaking coolant somewhere, so maybe its from here? But what is that circle thingy called? What does it do(beside leak lol)?
Old Nov 25, 2006 | 10:34 PM
Thats the pitman arm I believe. It doesnt leak fluid, it just looks like fluid is dripping into it.
Old Nov 26, 2006 | 02:44 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
wow good ole water blwon from the radiator fan, drove in rain lately i see...
Old Nov 26, 2006 | 08:43 AM
Ah, that makes sense....Nope, the car hasnt be driven at all lately since I got it. So maybe water from when before I bought it. Im going to dry it up and see what happens. Thanks.
Old Nov 27, 2006 | 05:04 PM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
The "Circle Thing" is the top of the power steering Box. If the fluid that you sponged off is green it is most likely coolant. The radiator might have a pin hole leak somewhere, leaky hose etc. Start the car and warm it up until the top radiator hose gets hot (thermostat open) and take a look in that area and see if you have mist or dripping occuring at that point along the radiator / hoses etc....
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
mfp189
Sep 27, 2015 09:25 AM
