tightening throttle linkage.
Old Nov 26, 2006 | 11:12 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
Hey guys, I have a 1991 305 TBI. And was noticing yesterday my throttle linkage is pretty loose near the TBI. How would I go about Tightening it? Thanks alot guys.
Old Nov 26, 2006 | 11:49 PM
Vader's Avatar
Is the throttle control cable or anchor point loose, or the throttle belcrank loose on the TBI throttle shaft?
Old Nov 27, 2006 | 12:08 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
Im really not sure of the name let me try and explain. there is a little shaft coming off the side of the TB, and a long elongated oval that goes around it, that actually pulls the throttle on the TB. that is loose i can move up back and forth quite a bit.
Old Nov 27, 2006 | 08:12 AM
Vader's Avatar
That sounds like the belcrank on the throttle shaft. The only good way to tighten it is to remove the throttle body, remove the throttle plates, remove the throttle shaft, and pein the end of the shaft back over the stamped belcrank (and possibly weld if necessary). They normally don't come loose unless they are subjected to excessive pull by the throttle cable. Once they are loose, the damage to the shaft begins to compound, thus, the possible welding to retain them.
DiabloWS6
20
Dec 11, 2015 04:12 PM
Fred SS
Oct 12, 2015 11:27 AM
Magman
Sep 14, 2015 01:30 AM
Randomtask2
Sep 7, 2015 05:06 PM
tonys91rs
Sep 2, 2015 07:07 PM
