sporadic idle and bad mileage
Old Nov 27, 2006 | 05:26 PM
bfox88's Avatar
Car: 90 IROC-Z
my car recently developed a real sporadic idle (but it never dies, just sounds like its about to then kicks back up. almost sounds cammed) and it seems to be getting kind of shotty gas mileage, is this the sign of a fault o2 sensor? it also sounds as if i have a bad exhaust manifold gasket, this couldnt be that big of an issue could it? what else could be the culprit. the car has recently had a full tuneup, head work, and all new gaskets. the motor is an L98
Old Nov 27, 2006 | 05:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is your SES light coming on?
Did these symptoms start after the work, or did they exist before it?
Old Nov 27, 2006 | 10:42 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
could be an injector stuck closed, therefor a dead cylinder, this would make the O2 sensors read lean and then richen up the mix on the rest of the cylinders. Therefor running rough and getting bad gas mileage. Bad ignition to 1 or more cylinders would also cause this.
Old Nov 28, 2006 | 04:15 PM
bfox88's Avatar
Car: 90 IROC-Z
no SES light, the car started doing this after all the work was done. the work was done because i had a bad intake manifold gasket so i was burning coolant and i was told this could f-up the o2 sensor?
xxx3man`
Sep 23, 2015 10:37 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
