more CID
Old Nov 27, 2006 | 10:18 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
more CID
Right now i put a 350 in place of the tired 305 in my camaro and i have been doing some research, i want to know what you engine masters think of the idea of replacing the standard 3.480 stroke crank with a 3.750" crank in my 350 without boreing it out. this should give me 3.77ci. (4.000 bore and 3.750" stroke) do you think i am stupid? or might it be worth it. A cast steel crank from eagle is like $200. I could nock this whole project out in a weekend. And if i do it i can use the regular 5.7" rods correct?
Old Nov 27, 2006 | 10:39 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
You would also need pistons.
Most stroker pistons come in 0.030 over, but im pretty sure you can find them that are stock bore.
Old Nov 27, 2006 | 10:58 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
The 350 engine i have has only 3 thousand miles on it, so my basic plan was to just replace the crank and keep those same bearings, or would you recommend new bearing (main and rod)? And then just bolt up those same rods and pisons. I can use those same regular 5.7" rods correct?
Old Nov 28, 2006 | 12:23 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
At least one part in the equation needs to be shorter. You can't just put a larger stroke on it or the pistons will SLAM into the head. That's why the recommendation was to change the pistons and keep the same rods. Stroker pistons will have a shorter distance between the pin and the top of the piston. This will compensate for the larger stroke on the crank.
Yes, on the new bearings. I recomend you use new bearings any time new (different) parts are put together.
Old Nov 28, 2006 | 01:57 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
It's called a stroker.
A lot of guys do it.
Yes it's worth it.
It would take a miracle to do it in a weekend.
Might as well just get a complete stroker kit, balanced and all.
Old Nov 28, 2006 | 08:07 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i dont think you know exactly what you're getting yourself into.
have you ever built an engine before?
Old Nov 28, 2006 | 05:47 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
your 3.75 stroke can be used with your stock pistons, but as stated above something has to get shorter...you can get a 3.75 stroker crank( it will need short counterwieghts) the rods you`ll need came stock in 400 inch sbc`s 5.565 length I believe. the whole mess will need to be balanced which ever way you go but it is no weekend project. Do yourself a favor too, do not buy one of those "pre balanced" kits they are far from being perfect for the xtra costs.
armybyrd
Sep 28, 2023 12:16 AM
masonta
Aug 31, 2015 10:14 PM
overdriv
Aug 20, 2015 03:52 PM
HrdRockA4305
Dec 18, 2001 10:15 AM
FSTFBDY
Feb 20, 2001 01:06 PM
