Cleaning existing fuel lines
Old Dec 5, 2006 | 04:37 PM
SmallTires's Avatar
Car: 1984 Camaro Z28
Engine: Roller 350
Axle/Gears: built ten bolt 3.73's
Well my car is about to hit the roads and I am very concerned after it sitting a year that the fuel lines might be gunked inside from not having fuel run through them. Is there any special solution I should sue to clean these? Keep min mind it is a carbed car so I am not meaning injector cleaner but something to run through the actual hard lines.
Old Dec 5, 2006 | 06:12 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Seafoam is supposed to work great, just pour it in your gas tank. Just remember to change out your filter since you might have gunk building up in there.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
